查看: 3593|回复: 1
老外评测7D的追焦能力,拍跑动中的狗,结果惊人!
deuced3795 发表于 2009-9-20 19:40:52 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
外国的7D測試http://www.robgalbraith.com/bins/mul...=7-10042-10239看看他的7D追焦測試心得-------------------------------------Continuous focus using Zone AF, nine points in the centre, AI Servo and the EF 800mm f/5.6L IS, tracking distant seagulls in semi-overcast light, the results were pretty good. The camera-to-subject distance wasn't changing too rapidly, but the position of the bird within the AF point group was changing constantly, and the camera handled this just fine.Continuous focus using Zone AF, nine points in the centre, AI Servo and the EF 200mm f/2L IS, tracking a running dog in fading light, the results were terrible. Over about 80 frames the camera got almost nothing usably in focus. If this result is representative of Zone AF, then Zone AF will be the way wrong choice for fast-moving subjects. We had better luck tracking the dog with Spot AF.-----------------------------------------------------第一段...拍攝移动速度较慢的..追焦性能不錯最後一段...连续追焦..跑动的狗...  追焦結果...  惊人80張...沒有一張准的
21
88
racialgan4 发表于 2009-9-20 20:59:02 | 只看该作者
总结了,7D确实就是60D,和1D没任何技术运用下放的关系。就是在50d的9点对焦中间塞进了10个点,整体覆盖范围相同,和1D的19点全F2.8两码事,因此也不可能有点测联动反光腔依然和50D是一摸一样的塑料腔体,和1D的设计无任何相似之处。Canon还是沒有像Nikon那樣的大方...直接把专业机身的AF   反光鏡組..下放到中端机身上或許只有把規格
